I want to make a pipe with 90 degree elbow made of sheet metal. I can't do a regular loft and change it to sheet metal because you can only change a part to sheet metal in one direction. I have tried "lofted bend" but I didn't see where you can pick the "guide path" if you have that ability. Also after I make the pipe I want to be able to place hole(s)/cut(s) into it and be able to flatten it.
PS: I have SW11
Good afternoon Thomas,
Welcome to the Forum,
Attached is how I do it, and I think you should be able to open with 2011, if not let me know and I can get you screen shots. How many segments did you want, also diameter of the pipe and elbow radius.
Later,
John
