Hi, there!
When I'm trying to start up my toolbox, I get this error message:
".\toolbox\swtoolbox.dll cannot be loaded. Either the add-in or its components is missing."
I'd like to know if I could possibly download the required file somewhere, or fix it in another way.
I've looked up if the file was missing in the folder tree, and it was.
Best regards
Eric
Hi Eric,
This file should reside in C:\Program Files\SolidWorks Corp\SolidWorks\Toolbox (default install location). If it's not there you might want to do a repair of the installation using the Installation Manager via the Add/Remove Programs panel Change button or a reinstall if the original installation was done via image. There may be some other files missing that you are not aware of and this approach should replace/repair everything for you. Sharing files can be sketchy if there is some discrepancy between what you get and what your system is expecting to see.
