1 Reply Latest reply on Apr 12, 2012 5:12 PM by Jamey Joye
    Surface Trim problems
    Jamey Joye
      I'm trying to automate a surface trim using a fit spline. What I have here is not working - when the AddTrimmingLoop2 function is called, Solidworks crashes. No debugging error, just a hard crash. The spline values are found using the 'Get BCurve Spline Points' Example, and is a single, closed spline describing the trim I want to occur. Does this function require more that one curve? Or does the surface need to be created within the scope of the function in order to access the TrimmingLoops?
      Is there a better way of going about this?
      'Function takes the cut curves data and trims the main surface (in the form of persistent sketch splines)
      Function TrimCurves(swModel As SldWorks.ModelDoc2, swSelMgr As SldWorks.SelectionMgr, CutArr() As Variant, persistID() As Variant) As Boolean
      Dim swFeat                   As SldWorks.feature
      Dim swSketch               As SldWorks.Sketch
      Dim bret                        As Boolean
      Dim swSelData              As SldWorks.SelectData
      Dim i                             As Integer
      Dim j                             As Integer
      Dim lastFeat                  As SldWorks.feature
      Dim typeName               As String
      Dim vFaceArr                 As Variant
      Dim uFace                     As SldWorks.Face2
      Dim cutSurface              As SldWorks.Surface
      Dim mainSurf                 As SldWorks.Surface
      Dim vBody                     As Variant
      Dim swBody                  As SldWorks.Body2
      Dim sBodySelStr            As String
      Dim sPadStr                  As String
      Dim sBodyTypeSelStr     As String
      Dim vSketchSeg             As Variant
      Dim swSketchSeg          As SldWorks.SketchSegment
      Dim noSpline                 As Boolean
      Dim segString                As String
      Dim isGood                    As Boolean
      'Spline parameters
      Dim numCurves           As Long
      Dim Order                   As Long
      Dim Dimen                  As Long
      Dim Periodic                As Long
      Dim NumKnots            As Long
      Dim NumCtrlPoints       As Long
      Dim Knots()                 As Double
      Dim CtrlPointsDbl()       As Double
      Dim UVRange(3)          As Double
          'Force Rebuild
          bret = swModel.ForceRebuild3(True)
          'Set data
          Set swSelData = swSelMgr.CreateSelectData
          'Find surface body
          vBody = swModel.GetBodies2(swSheetBody, True)
          For j = 0 To UBound(vBody)
              Set swBody = vBody(j)
              sBodySelStr = swBody.GetSelectionId
              Debug.Print "  " & sPadStr & sBodySelStr
              Select Case swBody.GetType
                  Case swSolidBody
                      sBodyTypeSelStr = "SOLIDBODY"
                  Case swSheetBody
                      sBodyTypeSelStr = "SURFACEBODY"
                      'get body faces
                      vFaceArr = swBody.GetFaces
                      Set mainSurf = vFaceArr(0).GetSurface
                      'Select surface body
                      'bret = swModel.Extension.SelectByID2(sBodySelStr, sBodyTypeSelStr, 0#, 0#, 0#, True, 0, Nothing, swSelectOptionDefault): Debug.Assert bret
                  Case Else
                      Debug.Assert False
              End Select
          Next j
      For i = 0 To UBound(persistID)
          'Set swSelData = swSelMgr.CreateSelectData
          Set swSketchSeg = swModel.Extension.GetObjectByPersistReference3(persistID(i), Empty)
          bret = swSketchSeg.Select4(False, swSelData)
          segString = swSketchSeg.GetType
      'Ensure spline inputed as a sketch segment
          If swSketchSeg.GetType = 3 Then
              'Find the spline parameters to pass to the trimming loop
              bret = SplineParams1.splineParameters(swSketchSeg, Order, Dimen, Periodic, NumKnots, NumCtrlPoints, Knots, CtrlPointsDbl, UVRange)
          Else
              noSpline = True
          numCurves = 1
          UVRange(0) = 0
          UVRange(1) = 1
          UVRange(2) = 0
          UVRange(3) = 1
          'Create the trimming loop on the Surface
           isGood = mainSurf.AddTrimmingLoop2(numCurves, Order, Dimen, Periodic, NumKnots, NumCtrlPoints, Knots, CtrlPointsDbl, UVRange)
      Next i
      End Function
        • Re: Surface Trim problems
          Jamey Joye
          So I've changed my tack slightly to be doing a surface cut on a solid body rather than trying to add trimming loops to the surface. I have lofted surfaces defined and selected and am using
          swModel.InsertCutSurface False, 0
          Which is giving me a desired result.. Most of the time. The other times the direction is 'wrong' - as in the feature keeps the wrong solid body. And this changes each time I go to debug. Is there any way to analyze that surface cut direction? Does it have a direction sense similar to a edge loop?
          Any thoughts would be helpful, cheers.
