I am using Solidworks 2012. I have created an equation curve which is also controlled by a dimension in the part, namely the distance between two planes.
Every time I change that dimension, I also have to go in the sketch and click on the curve and then exit the sketch in order for the curve to update.
Have you tried Ctrl Q?
