Hi everyone,
We are experiencing a huge time consuming problem here with a weldments file. It has has 300 bodies and when editing one of the feature, we talk about minutes waiting for the next step. For example, if we edit one of the feature's sketch, we have to wait a couple of minutes (2 to 3) just to go into the sketch. Once we are there, if we change one of the dimensions, let say 25mm instead of 20mm, we again have to wait 2 to 3 minutes after hitting the accept button. Same amount of time to get out of the sketch. Waiting time gets worst if we repeat these steps with a feature higher in the feature tree. I got an INTEL XEON, 16G of RAM with a QUADRO 4000. The file is worked from my machine and not from a network.
Does somebody has an idea of what's going on? I cannot believe I'm the only one with that kind of problem.
Sounds like the rebuild time is extensive. Have you used Tools -> Feature Statistics to see which features are impacting the rebuild?
If you are using SW2012, there is a tool called feature freeze which can help reduce rebuild times.
Which SW version are you using?
