I recently changed to 2012 SP2 from 2011. I am finding that sometimes when I import a STEP file (from a vendor web site) when I go to save the resulting .sldprt I get a "unknown error has occurred" error. It does not matter where I try to save it. The workaround I found was to export the .sldprt file to a step, import that step and then I am fine. Anybody else run into this? It may be specific to this one vendor but the file does import to a valid solid.
John
I can't up load the STEP file but here is the vendor page:
http://www.molex.com/molex/products/datasheet.jsp?part=active/0878320606_PCB_HEADERS.xml
I had the same issue, Caddedge support solved the issue by having me uncheck in the STEP options "Map configuration data".
Go to "Open part file"
Change file type to STEP/STP
Pick "options" at bottom
Uncheck where it notes "STEP" map configuration data.
Bob
