I’m having trouble getting Pro/E files to check back in after a variable is updated. The code below checks out and updates the variable correctly for SolidWorks and Pro/E files (as evidenced in the Data Card). It then checks in a SolidWorks file just fine but fails on all Pro/E files with the error: E_EDM_INVALID_FILE, The format is not recognized. But the file is already in the vault so obviously it is a recognized format.
I am using Enterprise PDM 2012 SP1.0 with the EPDM Addin “Add/Renamer” from SolidWorks and the Pro/E Connector for Wildfire 5.0. I'm compiling the .NET 4.0 code in MSVB 2010 Express and using Interop.EdmLib 5.15.
Note: If I comment out the Update the Variable section, the Pro/E files check out and in just fine. The error only occurs when I change something.
Here is the code
Imports EdmLib
Module Module1
Sub Main()
On Error GoTo Err_Main
Dim Vault As IEdmVault7 'Vault object
Vault.Login("Admin", "PassWord", "PDM_Vault")
Dim myFileObj As IEdmFile5 = Nothing
Dim MyRetFldrObj As IEdmFolder5 = Vault.RootFolder
Dim FilePath As String = "C:\PDM_Vault\Projects\Test Area\CAD\101-A20020.drw"
'Dim FilePath As String = "C:\PDM_Vault\Projects\Test Area\CAD\101-A20020.slddrw"
Dim loc As Integer = Len(FilePath) - InStr(FilePath, ".")
Dim FileExt As String = UCase(Microsoft.VisualBasic.Right(FilePath, loc))
MyRetFldrObj = Vault.RootFolder
myFileObj = Vault.GetFileFromPath(FilePath, MyRetFldrObj) 'Get the interface of the file and its parent folder
myFileObj.LockFile(MyRetFldrObj.ID, 0) 'Check out the file
'***************Update the variable***************
Dim varEnum As IEdmEnumeratorVariable8
varEnum = myFileObj.GetEnumeratorVariable
Select Case FileExt
Case Is = "SLDDRW"
varEnum.SetVar("Revision", "@", NewRev)
Case Is = "DRW"
varEnum.SetVar("Revision", "generic", NewRev) '<-- Not sure if "generic" is the correct configuration name to use. It does update the datacard correctly.
End Select
varEnum.Flush()
varEnum.CloseFile(True)
Dim NewRev As String = "A"
myFileObj.UnlockFile(0, "Revision variable updated to " & NewRev & ".") 'Check in the file with comment *** Here is where if fails ***
Exit Sub
Err_Main:
Dim ErrName As String = ""
Dim ErrDesc As String = ""
If Not Vault Is Nothing Then
Vault.GetErrorString(Err.Number, ErrName, ErrDesc)
MsgBox("ErrHld initiated. Errors: " & ErrName & " " & "Description: " & ErrDesc)
Else
MsgBox("Error Number: " & Err.Number & " Description:" & Err.Description)
End Module
Any Suggestions?
Just a shot in the dark... try changing this line:
to
varEnum.SetVar("Revision", "", NewRev)
Elsewise the code looks pretty good.
