TOTyler Olney04/04/2012
I've designed a basic solid object that was then copied about an axis using the circular pattern feature. My question is, is it possible to merge these now five seperate objects into a single solid object? The reason I ask is it may be converted into sheetmetal, and a single object would make turning it into a flat pattern a bit more efficient in terms of the design process.
This is being designed in Solidworks 2011.
Thanks in advance,
-Tyler
