Hi
I know this is probably a really stupid question but i cannot work out how to change the mesh quality to draft as opposed to high.
I am using solidworks simulationXpress in solidworks student design kit 2011
Andrew
Hi
Andrew
Welcome to SolidWorks forums Andrew.
This should help you: Changing the mesh settings in SimulationXpress
You might also find this post helpful for your future reference.
Thank you for the reply.
I understand how to change the mesh density from coarse to fine, however i have not been able to Mesh property manager, see http://help.solidworks.com/2012/English/solidworks/cworks/idc_help_preference_mesh.htm, to change to draft/high quality
Andrew
Those option are not available under SimulationXpress but under SimulationWorks and above. Try add-in the Simulation under Tools > Add-Ins and then run the Simulation to get these option.
In the add-ins section there are only 3 options;
Autotrace, Photoview 360 and Solidworks XPS driver.
Can i download the simulation add-in from somewhere?
I'm not sure if Simulation is available in Student Design Kit but it is available in SolidWorks Student Edition
