I am trying to import an assembly from Solidworks into another software (MAGMAsoft) is there a way to set it up so when I save my assembly it will import into MAGMA in the same position? Currently Solidworks always turns my models and changes the location of my origin. I export the files as STLs
Thanks!
A few questioins...
1. Is your model / assembly that you are exporting in the proper orientation to start with?
2. Is there a reason you are using STL? If can use STEP or SAT that would be better then STL.
Watch this video to learn how to add and use a user defined coordinate system.
http://www.youtube.com/watch?v=lfrDhdj6McY&feature=plcp&context=C4b7334aVDvjVQa1PpcFNGrs2l5-AYCpl5M2SsyoCkMFy24y9kDVw%3D
