The working folder location for a web client installation is C:\Users\user_name\Local\SolidWorks\SolidWorks Enterprise PDM\Cache\ . This means the folder location will be different for every user.
AutoCAD stores xref path within the dwg file, this information will only be useful for the original user. Each user will need to manually load each xref file.
I would like to force the web client to cache EPDM files in a common folder (C:\Jobs). Is this possible?
Hi Tod,
The easiest way is to install the thick client of EPDM, If EPDM client is installed and with a local view, the web client will use this path to cache files.
If you cannot or do not wish to install the normal EPDM client, you can change it manually with a few steps, one of witch is changing a registry key.
Contact your local var to assist you in getting access to this information.
Regards,
Pedro Branco
