We are still on 2006, so I'll have to start at the server. I
was going to hold off on upgrading PDMWorks to 2007 until we go to
SW 2007. On the advice of our VAR (and our ouwn tendency to play it
safe) we are waiting for SP1 before we do that.
Actually - I forgot to ask what version you are running 2006
or 2007?
If you are running 2006, you must update the server first.
As a general recommendation, you should update the
server....
Thanks. I was wondering if I could avoid that by updating the
clients first. Would they have any issues using the vault until it
is updated as well? I have to find a time when I can interrupt the
users and get the clients updated, then coordinate a time with our
IT folks to access the server and upgrade that (on the other end of
the building). There could be a couple of hours in between, so I
was hoping everyone could keep working in the mean time. Will that
work?
on 2006 19 11:21 Joy Garon wrote:
> Nope - but, if you are lazy like me you would update the
server and when a client
> tries to connect they will be given the option to update
at that time.
server and when a client tries to connect they will be given the
option to update at that time.
The answer to this may be here somewhere, but I couldn't find
it right away and was hoping for a quick answer. Does it matter if
I apply service packs to the server or clients first? If I do the
server first, will the clients still work until I upgrade them, or
must they always be at the same SP? What about vice-versa(upgrading
client before server)? They will all be upgraded within a short
amount of time, but I was wondering if I can upgrade one side and
allow work to continue until I can get to the other side.
Thanks.-
As a general recommendation, you should update the server....
> Nope - but, if you are lazy like me you would update the server and when a client
> tries to connect they will be given the option to update at that time.
kb
