Not able to check out assembly file,if other user has checkedout a part drawing?
I need to check out a assembly file, but other user has checkedout a drawing. the drawing is of a part which is used in the assembly.
I thought EPDM allows multiple user to use the data base at a same time. why EPDM is not allowing to use multiple files by multiple people?
or is ther an option to allow multiple users t work on multiple fies?
regards
vinay
Perhaps you could give more details about your situation. What exact error or other message are you getting when you try to check out the assembly?
Are you sure you have the permissions set correctly?
There are warnings listed in the PDM users and groups dialogs that can be set to block certain operations under certain conditions. Check to see that these are not set too restrictively.
