10 Replies Latest reply on Mar 22, 2012 11:43 AM by Alin Vargatu
    Insert Multiple Components Simultaneously
    James Bailey
      I received some part data from a customer. There are around 60 components that make up this assembly which I have to put together piece by piece. Since it did come from a single assembly before, I'm able to simply go to insert and click the green check button to have it snap in place.
      My question is if there's a way to insert multiple part files at once. When I go to insert these files, I'm not able to control click (or shift click) to select all of these components to add to the list to click the green check button and have them insert simultaneously. I can't do a drag and drop because they won't snap to the origin then and therefore won't be in the correct position.
      This is quite a tedious task and I would appreciate any advice.
      Thanks!
