I was able to generate a sheetmetal part within a weldment. While in the drawing, the view of the sheetmetal part comes in just as well as the rest of the items. I can't figure out how to bring the flat pattern into my drawing. Does anyone hav a solution? Thanks
When you insert your component notice the "Select Bodies" option in the list. By choosing this option you are able to specify single or a selection of components to bring into a drawing view. In the instance of sheet metal, you can select that component alone, and then it will allow the flat pattern to come through.
Cheers.
