Hi everybody
I am trying to generate certain cuts in a flat surface, but my idea is to only create one sketch, generate the cut and then make the LINEAR pattern with that Surface Trim. I want to do the work this way, because sometimes is messy to control the patterns inside a sketch. The problem is that the linear pattern tool is not for this type of features (I think) is there another way of making the cuts I want?
In the image I am talking about the S shape cut that is marked.
Thanks!!
May be you can start with a solid base, do the cut and linear pattern and then either delete all the faces excpet the top/bottom one or offset top/bottom surface/face and delete the body.
