I have bee trying change the Material Properties of the componets within an assembly but at the assembly level (part-instance@assembly) and have so far failed. I have been able to successfully change the properties at the part level through the assembly by selecting the parts and then using the assembly ModelDoc2.MaterialPropertyValues. If I select the parts by name, using the partname-instance "@" assemlby name convention nothing happens. I can change the top level color for the assembly using the ModelDoc Extension.SetMaterialPropertyValues for the assemly.
Code for changing assemlby top level Material Properties
IModelDoc2 modDoc = default(IModelDoc2);
// Get the current document
modDoc = (IModelDoc2)iSwApp.ActiveDoc;
// Create a null object for SetMaterialPropertyValues
object oNull = new object();
// Set properties array [ R, G, B, Amb, Dif, Spec, Shine, Trans, Emis ]
Double[] properties = { 1, .5, .25, 0.5, 0.5, 0, 0, 0, 0 };
// Set the properties
modDoc.Extension.SetMaterialPropertyValues(properties, (int)swInConfigurationOpts_e.swThisConfiguration, oNull);
...end code
Code for changing part level Material Properties within an assembly
IComponent2 swComp = default(IComponent2);
IModelDoc2 compDoc = default(IModelDoc2);
// I'm just testing with one preselected part here
// Note: preselection gets the part level, not assembly component level
int count = modDoc.SelectionManager.GetSelectedObjectCount2(-1);
if (count == 1)
// Get the component of the selection
swComp = modDoc.SelectionManager.GetSelectedObjectsComponent3(1, -1);
// Get the modeldoc of the component
compDoc = swComp.GetModelDoc2();
compDoc.MaterialPropertyValues = properties;
...end code
I think I may have been looking at this too long. Does anyone know how to accomplish this?
Thanks in advance!
