Hello everyone,
Is there a way to build a piping system in Solidworks using specifications on the the diameter of the pipe, covering, fittings flanges to be used, and so on.
This is in order to the designer follows the lead rules and avoid he puts any component that not complies the specifications of the spool he is designing. The idea is that when accessing the library of components, the parts that fullfill the design rules on that specific line are the ones only available.
I know there is a partner called Smap3D that uses this kind of workflow. But, It is this can be done in Solidworks? or there is a workaround?
Regards
Jose
Hi Jose,
Did you try using the piping and instrumentation tab? Perhaps that could work for you, but the big disadvantage is that SolidWorks doesn't currently offer a easy way to build the list files.
Hope this helps,
Alecs
