Edit Rhino files using 'right-click' in feature-tree?
Question asked by Scott Borstad on Mar 19, 2012
Latest reply on Mar 21, 2012 by Scott Borstad
I recently upgraded from SW2011 to 2012.  Our office uses Rhino a lot, and I need the capability of opening rhino files from SW... but in 2011 I used to be able open a Rhino model and have it import, click no to 'run diagnostics', then right-click on one of the imported surface features that were listed in the file tree and be given two options:
1) Edit in Rhino
2) Refresh
Both were very useful, and they would do excatly what they woudl indicate... allowing the user to make changes to surfaces in Rhino and bring those changes in seamlessly to SW.
After install, I lost this capability.  I called my VAR and they were able to verify that they had the right-click functionality using the same rhino file in both SW2011 and SW2012.  Under their guidance I:
-uninstalled Rhino
-did a clean uninstall of SW
-reinstalled Rhino V4sr0
-re-installed SW2012sp2.0
The above didn't solve the problem though, and I still don't have the functionality of 'edit in Rhino' and 'refresh'.
I urgently need a fix for this one... if anyone has run across this behaviour or has seen this before, I would really appreciate a message.
Thanks a bunch!
-Scott
