When I render the depth of field is not working. I'm using 2011 SP2. No matter what I set the DOF to my entire model renders in focus. Anybody have this problem? I have 2010 installed as well and if I load a model into the external Photoview 360 that DOF renders fine but when I use the intergrated PV360 in 2011 it doesn't work at all. Using 2010 is not really an option since my model was done in 2011.
Any ideas?
Never mind. I figured it out. I was simply not getting nearly agressive enough with narrowing the DOF. Using even a moderately wide angle(35mm) it takes a DOF setting below 1" to see even moderate blurring at like 18-24" past the focus point. Don't know why they couldn't have stuck with an actual f-stop setting.
