Hi all!
I'm having problems defining an "Internal Fan" boundary condition. When I run the model and the solver is finished, it does not seem that the fan has worked!
Please, explain the appropriate procedure in modeling/defining an internal fan. Which faces should be used when selecting enter and exit flow faces? Should we have a block part representing the fan? What is the overall algorithm?
Thanks!
-Ramin
Make sure you have a correct fan curve. I had a fan curve that started at zero pressure and zero flow rate and obained "no flow".. The curve should start at a pressure greater than zero at zero flow rate and continue from there.
