9 Replies Latest reply on Jun 1, 2012 4:04 PM by Alicia Starr
    autocad versus solidworks 2020
    Alicia Starr
      I want to know if there is a way to match properties in solid works same as in autocad, when you match properties in autocad in a dwg you click on an item (like text) that is in layer format and font is arial, you want only some items to have this properties,  and in autocad you click n the original text then you clik on the other items you wnat to mathc the properties . so is there a way of doing this in solidworks without having to do the task over and over
