5 Replies Latest reply on Mar 8, 2012 8:41 AM by Dean Dickemore
    Solidworks Machines?
    Craig Geiger
      I'm looking to upgrade my Solidworks machine but am looking form advice on what graphics card, amount of RAM and what type of processor I should be looking at.  We run Solidworks 2012 and do rather large assemblies. Sometimes these assemblies can be 2000-3000 pieces.  My machine now was built in 2010 it is 12 GB, NVIDIA Quadro FX1800 768MB video, Win7 64, Intel I7-980x Extreme Processor. Should I be looking at Quad or Dual core?
      The problem I am having is the when I get into these large assemblies I am spending a good 20-25 minutes per hour watching the little cherrio spin as the model save or regenerates
      Looking for ideas
        • Re: Solidworks Machines?
          Rohit Mitra
          Any issue with rotating the model or graphics?
          In terms of saving, you're going to want to get a machine with a solid state hard drive. That will save you quite a bit of time saving and loading. I would start there as your processor is plenty fast, and you have plenty of ram. The specific issues that you mentioned wouldn't be graphics limited.
          If at the end of the day you need more processing power, the i7-2600k would benefit you, if you overclock. Keep in mind the performance from the 980x and a chip like the 2600k isn't much out of the box, so like I said that would require overclocking the 2600k to see advantages.
          How large are your assemblies? With your specs I'm surprised that you have slow rebuild times. With the slow saves, I assume you have a 7200rpm drive? So the afformentioned SSD will help quite a bit.
            Anna Wood
            If you are getting constant regens and rebuilds that is usually an indication of a circular reference.  Find and fix that and you should not be waiting for rebuilds.
            You have a fast computer, I think you may have other more fundamental issues with how your assembly is built.
            Give us more detail on your assembly.  Types of parts, how feature rich, does it have a lot of patterns.  Do you have a lot of errors in the Feature Tree that are not fixed? Can you post a picture of what you are working on?
            What does it appear to be waiting on or stuck on while working on your assembly.
            Do you have the SolidWorks approved drivers for your system and video card installed?
            http://www.solidworks.com/sw/videocardtesting.html
            Cheers,
            Anna
              Dean Dickemore
              There is a well written set of tips here, http://blog.cati.com/maximizing-solidworks-performance/ that cover a great many tweaks that can be made to the OS as well as SolidWorks.  I've employed many of them with good results.  Pushed them out to my 30+ users as well, and it has made our team more efficient as a whole.
              Enjoy.
