0 Replies Latest reply on Mar 7, 2012 3:21 PM by Tom Cote
    Creating an XML file from a BOM on a SW drawing
    Tom Cote
      Hi all,  I'm trying to create an XML file from a BOM on a drawing.  But there is a little catch to it.  The drawing may have several BOM in it and none have the correct columns for what I need.  So I've been piecing together code, some from the SW website, some from other resources on the web and some I wrote.  in the code that I have I insert the correct BOM and then "search" the tree for the last BOM.  From there it does create the XML file with everything configured correctly except that it is grabbing all the BOM's not just the one which I have the name of.  Any help to narrow this down would be greatly appreciated.
      PS I have no problem to put the actual macro up here if it helps.
      Option Explicit
      Public Enum swTableSplitDirection_e
          swTableSplit_None = 0
          swTableSplit_Horizontal = 1
          swTableSplit_Vertical = 2
      End Enum
      Sub ProcessTableAnn _
      ( _
          swApp As SldWorks.SldWorks, _
          swModel As SldWorks.ModelDoc2, _
          swTableAnn As SldWorks.TableAnnotation, _
          XMLfile As Scripting.TextStream _
          Dim nNumRow                 As Long
          Dim nNumCol                 As Long
          Dim nNumHeader              As Long
          Dim sHeaderText()           As String
          Dim i                       As Long
          Dim j                       As Long
          Dim k                       As Long
          Dim nIndex                  As Long
          Dim nCount                  As Long
          Dim nStart                  As Long
          Dim nEnd                    As Long
          Dim nSplitDir               As Long
          nNumHeader = swTableAnn.GetHeaderCount: Debug.Assert nNumHeader >= 1
          nSplitDir = swTableAnn.GetSplitInformation(nIndex, nCount, nStart, nEnd)
          If swTableSplit_None = nSplitDir Then
              Debug.Assert 0 = nIndex
              Debug.Assert 0 = nCount
              Debug.Assert 0 = nStart
              Debug.Assert 0 = nEnd
              nNumRow = swTableAnn.RowCount
              nNumCol = swTableAnn.ColumnCount
              nStart = nNumHeader
              nEnd = nNumRow - 1
          Else
              Debug.Assert swTableSplit_Horizontal = nSplitDir
              Debug.Assert nIndex >= 0
              Debug.Assert nCount >= 0
              Debug.Assert nStart >= 0
              Debug.Assert nEnd >= nStart
              If 1 = nIndex Then
                  ' Add header offset for first portion of table
                  nStart = nStart + nNumHeader
          If swTableAnn.TitleVisible Then
              XMLfile.WriteLine "                <TITLE>" & swTableAnn.Title & "</TITLE>"
          ReDim sHeaderText(nNumCol - 1)
          For j = 0 To nNumCol - 1
              sHeaderText(j) = swTableAnn.GetColumnTitle(j)
             ' Replace invalid characters for XML tags
              sHeaderText(j) = Replace(sHeaderText(j), ".", "")
              sHeaderText(j) = Replace(sHeaderText(j), " ", "_")
          Next
          For j = nStart To nEnd
              XMLfile.WriteLine "                <material>"
              For k = 0 To nNumCol - 1
                  XMLfile.WriteLine "                    " + _
                      "<" + sHeaderText(k) + ">" + _
                          swTableAnn.Text(j, k) + _
                      "</" + sHeaderText(k) + ">"
              Next k
              XMLfile.WriteLine "                </material>"
          Next j
      Sub ProcessBomFeature _
      ( _
          swBomFeat As SldWorks.BomFeature, _
          Dim swFeat                  As SldWorks.Feature
          Dim vTableArr               As Variant
          Dim vTable                  As Variant
          Dim swTable                 As SldWorks.TableAnnotation
      Set swFeat = swBomFeat.GetFeature
          XMLfile.WriteLine "        <materials>"
          vTableArr = swBomFeat.GetTableAnnotations
          For Each vTable In vTableArr
              Set swTable = vTable
              ProcessTableAnn swApp, swModel, swTable, XMLfile
          Next vTable
          XMLfile.WriteLine "        </materials>"
          Dim swApp                   As SldWorks.SldWorks
          Dim swModel                 As SldWorks.ModelDoc2
          Dim swDraw                  As SldWorks.DrawingDoc
          Dim swSheet                 As SldWorks.Sheet
          Dim swBomFeat               As SldWorks.BomFeature
          Dim sPathName               As String
          Dim nNumSheet               As Long
          Dim nRetval                 As Long
          Dim i                       As Long
          Dim bIsFirstSheet           As Boolean
          Dim bRet                    As Boolean
          Dim fso                     As Scripting.FileSystemObject
          Dim XMLfile                 As Scripting.TextStream
          Set swModel = swApp.ActiveDoc
          Set swDraw = swModel
          bIsFirstSheet = True
      ' This section adds the BOM to the Drawing
      Dim Part As Object
      Dim boolstatus As Boolean
      Set Part = swApp.ActiveDoc
      boolstatus = Part.ActivateView("Drawing View1")
      boolstatus = Part.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0.03907265301171, 0.269313374338, 0, False, 0, Nothing, 0)
      boolstatus = Part.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0.07054146514819, 0.2598727306971, 0, False, 0, Nothing, 0)
      Part.ClearSelection2 True
      Dim swActiveView As Object
      Set swActiveView = Part.ActiveDrawingView
      Dim swBOMTable As Object
      Set swBOMTable = swActiveView.InsertBomTable2(False, 0.03515977505523, 0.3102228301154, swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopLeft, swBomType_e.swBomType_PartsOnly, "XA67607Q (dia 1.75)(bul 05)", "C:\Documents and Settings\Tom\My Documents\Dropbox\ACS\RHF\VMTEMP\XML to VM-BOM.sldbomtbt")
      ' Done adding the BOM
      ' This is getting the feature name, extracting BOM
          Dim BomName As String
          Set swFeat = swModel.FirstFeature
          Do While Not swFeat Is Nothing
              If "BomFeat" = swFeat.GetTypeName Then
                  Debug.Print "******************************"
                  Debug.Print "Feature Name : " & swFeat.Name
                  Set swBomFeat = swFeat.GetSpecificFeature2
                  BomName = swFeat.Name
              Set swFeat = swFeat.GetNextFeature
              If swFeat Is Nothing Then
                  GoTo Line2000
          Loop
      Line2000:
      MsgBox BomName 'verify that I have the correct BOM
      ' Done getting the BOM name
          ' Strip off SolidWorks file extension (sldxxx)
          ' and add XML extension (xml)
          sPathName = swModel.GetPathName
          sPathName = Left(sPathName, Len(sPathName) - 6)
          sPathName = sPathName + "xml"
          Set fso = CreateObject("Scripting.FileSystemObject")
          Set XMLfile = fso.CreateTextFile(sPathName, True)
      '   Visual Manufacturing Header Text
          XMLfile.WriteLine "LSAXML"
          XMLfile.WriteBlankLines (1)
          XMLfile.WriteLine "<cad>"
                  ProcessBomFeature swApp, swModel, swBomFeat, XMLfile
          Loop
          XMLfile.WriteLine "</cad>"
          XMLfile.Close
