I would like to ask you something. How I can seperate one angle in two equal angles in assembly?or how I will set that two angles will be equals in assembly.
Thank you in advance!
thank you for your answer!But how I will use equations in assembly?I'm asking if there is something that I'm missed!
Jeremy thank you!I've add angular dimension in the three parts that I want to have the same angle but if I double-click the dimension then the modify dialog box doesn't appear so that I can select Add Equation from the dimension value list. I also tried from Tools>Equations and I set ( "RD2@Annotations"="RD1@Annotations" ) but it's not working!
What are you trying to do in this assembly that you want one angle set to 2 equal angles?
If this is for a mating/orientation purpose within the assembly for instance, you can easily use a reference plane.
you can use equations or linked values (pre-2012) to make vaule equal.
