I'm sectioning an Assembly to check for clearance and when sectioned some of the Parts appear empty or shelled (when viewing directly at the sectioned face), so they just have a very thin outline, while other are solid. I've created all the parts the same way.
Any reason for the difference or how I can make them solid?
Thank you!
A couple things come to mind, but there are reasons why they don't make sense.
The first is that you have the section cap turned off, but that should affect all parts at the same time. The other is that the "thin" parts are actually surface parts, not solid parts, do to whatever. But you think you created them all the same so thus the lack of explanation there.
WT
