Ok Can someone give me a breif description of how it is used. There has to be some tricks, I never seem to get the option.
I was told that I could take a part and insert a block around it and use the cavity tool to make a cavity in the block and then cut the block to to make a cavity and core if so how does it work in assembly or multi body.
Joe
Joe,
You are exactly correct. That is how I have used it.
Check out this instructional video in Youtube using the cavity command.
http://www.youtube.com/watch?v=vgwdhh-JtmY
