Hello fellow solid-workers.
I have an assembly (A), build up out of several sub-assemblies (B). All sub-assemblies (B) are similar, except they have different configurations. Each configuration consists out of supressed and un-supressed parts. also there are various parts which are present in all sub-assemblies (B).
Now I want to create a standard sheet, becouse this assembly (A) will be used in several projects, only with a different number of sub-assemblies (B) with different configurations.
for example:
Assembly (A) has 12 sub-assemblies (B) with configuration 1, and 4 sub-assemblies (B) with configuration 2.
Sub-assembly (B) configuration 1 contains 2 parts (X), 1 part (Y) and 4 parts (Z)
Sub-assembly (B) configuration 2 contains 1 part (X), 4 parts (Y) and 4 parts (Z)
I want to know how many parts (X), (Y), (Z) and how many of each configuration there are in the whole assembly (A), and not have them listed for each sub-assembly (B) seperately.
How can I create a BOM which counts the number of configurations (this part I know), but also counts the number of similar parts used by these configurations.
Thank you in advance.
Roel,
Welcome to the forum.
When you place a BOM in the drawing and if you select it in the property manager of the BOM
you will see a section that says which configurations you want shown in the BOM. I would start there
and see what that gives you and if it starts to give you what you are looking for.
