What am i doing wrong with this simple part, when i go to flatten i get and error
Good morning Isaac,
Why this happens I'm not sure, however that is one of the reasons that I don't use the Base Sheet Metal features. This doesn't happen when you model, (extrude), your part and then insert bends.
This only show up after you drop the part into the drawing and ask to insert the flat pattern view, my guess it's a bug or a setting that needs to be checked, however I don't use that technique anymore.
Suppress all the features in both configurations and unspress what is needed in both configurations, and it will work from then on,
Later,
John
Not sure what you did in that file, but I deleted the sheet metal features, leaving only the sketch, and just remade the base flange and it worked fine. I am on 2012 SP2 though so there might be something going on with your version. What are you using?
WT
