I have attached a solidworks 2010 file ! Its basically about making racing car seat using surface loft. I have made profiles and guiding curve too. but when i select profiles and then apply loft base it gives following error:
Cannot knit sheets together.
Help please Its urgent !
Hi Debasish,
Check your 3dsketch3-7; First just build 1/2 of seat and then miror, Second, they are not properly coincident to your sketch1. For a better solution - You might also want to consider using fit spline to convert your arc-line profiles into single smoother curves or use a single spline instead of arc-line segments. See attached and notice 3 configurations for 2 different solutions.
Regards
Mark
