Hi Everyone, I am at the Tooling Split stage of a mould design, having created the Parting Line and Parting Surface, all looking good so far. However when I enter the Block Sizes of 100mm and 70mm respectively, it projects these sizes from the Part Origin, not the Parting Surface. The Part (imported) has it's Origin 2.012mm above the Parting Surface (inside the Cavity) so I end up with a Core block size of 67.988mm and a Cavity of 102.012mm. I have no interlock checked and have entered "Parting Surface 1" in the "Parting Surface" box at the bottom. I know I can just get around this by fiddling my Block Sizes to take account of the 2.012 offset but this cannot be right..............can it please?
Roger
Roger,
The block thicknesses that you are inputting basically work the same as an extrude with a blind end condition. They start at the sketch plane and end at the distance you specify. You can either reposition your part after importing to place its origin on the plane that you used to sketch you insert profile or you can create a plane at the part origin where it sits and use that new plane to sketch your insert profile.
Hope that helps,
James Ceszyk
