How do I change a files thumbnail preview view orientation?
I am making a electronic Part to match the JDEC so the top view is in a similar orientation for use with circuit works. But, I would like the Thumbnail to be in a different orientation to show the part better.
I saw this question below in a forum search from 2007. A lot has changed since then, but a lot of the improvements are in less used areas and not this we use everyday like the thumbnails or redefining the ISO view.
Thank you,
From 2007...
How do I change a files thumbnail / preview view orientation?
"I would like to control the display of individual files and directories. Is there a setting that can be changed?"
There is an option in the document properties>image quality that says use isometric, zoom to fit for document preview. If you want to set the view yourself you need to deselect this option set the view for the part then save it this will make your thumbnail look the way it was saved
