Hello!
I´m modelling a bended plywood seat for a chair and I have made a "plywood" mapping in photoshop. It looks ok in sides, but in the front edge it should be bended. Is possible to do some how? If I remember right, bending was possible in 3DMwax, which I have used in past.
Or is the only solution to make a bended mapping for that in photoshop?
A-P
You should be able to select the faces and apply it as a decal, but not as a material.
If you have a bump map to go with it, then you may need a 3ds max or modo type program where you can uv-unwrap it.
