Thanks Deepak Gupta I am able to create Forming Tools, Save them in the appropriate place, and even place it onto my model but now I am getting an error message ..... Error Gusset H05232 The part's thickness may not be compatible with this form tool. The thickness must be less than the minimum radius of curvature for the form tool..... What is this all about All the radii in my Form Tool are larger than the part thickness???
I had no issue with the forming tool you originally supplied other than the color, it worked fine on your bracket I just needed to add it again and delete the one you had already inserted.
