I am working on an assembly that is supposed to be at an angle. is there any way to change so when i select any of the standard views it orients it at the right angle?
It's hard to say without seeing how the parts are mated, but if they are all mated to the first part brought in then you should be able to float it and then re-mate it to the assembly planes at the desired angle.
Here is a YouTube video I did for someone else that needed to do something similar, Basically you orient the assembly the way you want it for one of the standard views, select the view and "Update Standard Views".
