Hi
I have a project where i have drawn a handrail using the sweep function. the sweep function uses a profile and a projected curve, now the hard bit, can i transform or "Flatten" this shape some how so i detail out a drawing, so a person can take a straight piece of steel and begin to bend/shape it.
I attached the part file to this post below.
Any help or advise would be great.
Thanks in advance.
James
Good afternoon James,
If you can do a offset curve lines like the picture below than do a sheet metal loft and you should get the flat pattern,
Later,
John
