Hello all,
I am making an extruded cut in an assembly.
The rectangular cut boundary sketch surrounds the parts that need to be chopped. - See picture below
However, the cut does not cut through one of the components as the picture below shows.
Also i have found this is spr 189296.
Would anyone know a way around this?
Many thanks.
Hadleigh,
When you create the cut in the dialog window this part is not excluded is it?
I am guessing that the results may be unfavorable if it does cut through.
Basically some geometry that SW will have difficulty creating.
Try creating a smaller cut box in a different location and see if that works.
