Sub Assy. current configuration display in the Main Assembly
Question asked by Thilagaraj Nagaraj on Feb 17, 2012
Latest reply on Feb 17, 2012 by Josh Brady
Dear Friends
Solidworks 2008
I have 2 Assembles namely `S' and `M' and `S' is inserted inside the `M'. So we call `S' as Sub Assembly and `M' as main assembly. Now `S' has two configurations namely `Default' and `modified'.
If i opened and saved the `S' with `modified' configuration and closed it. Then i opened the `M' means inside `M' `S' should be displayed with `modified' Configuration. But `S' is displayed inside `M' with `Default' Configuration.
I can change this using inside `M' main assembly, select `S' sub assy. in Feature Manager design tree, Right Click > Component Properties > `Configuration Specific Properties' area `Referenced Configuration' configuration selection sub area - here i have to change from `Default' to `modified'.
Each and every i have to change this, also this is no relation with Inside `S' Sub Assy. Configuration changing.
If there any facility / options to change the `S' Sub Assy. Configuration inside `M' main assy. by Inside `S' Sub Assy. Configuraion
thanks in advance
thilagaraj
