Hy....I'm creating a 3d sketch on a surface with Spline on surface command. The problem that i'm having is that can't extrude this sketch, i'm geting this message : "The direction of extrusion must be specified for 3D sketch". What settings should i use?? Thank you.
Hi Cosmin, to extrude a 3D sketch, you need to pick a plane or edge to specify the extrusion direction. To do that, pick in the field underneath the extrusion type list and then select an edge or plane from your model.
I made a screen capture but Internet Explorer isn't letting me upload it, so let me know if you need me to explain it a little more.
John
