I just had my computer swapped out with a new install of SolidWorks and PDM Enterprise. I don't have the PDM task pane on the right side anymore, only the other items like Home, design library ect. I put in a call to MCAD but they have not responded yet, is there a way to turn on the PDM enterprise task pane so I can check out and check in files from SolidWorks and not have to close down the whole assembly and check in from the PDM browser.
Thank you
If that is the case, then they did not properly install the EPDM client software on your new machine. Someone will need to modify the EPDM install and check the box to install the SolidWorks Add-in.
