I have a Revit model I'd like to import into SW. I've tried DXF but it says it's outside the parameters. It's of an acre of land. What else can I try?
Doug,
These are the import option inside of Solidworks.
Does Revit have any of these as an export?
If it is in there then export it as one of them and then in Solidworks
use the open dialog window then for file type select the down
arrow and select the appropriate type.
Hope this helps.
try a parasolid, step or iges.
