Is it possible to select all toolbox parts in an assembly so they can be quickly deleted in order to add the correct parts from a new toolbox?
thanks in advance,
Derek.
thanks in advance,
Derek.
It depends on witch version of sw you use. From 2008 or 2009 you can press "s" key in assembly and you have select (arrow) with options. On 2010 you have the option "Select Toolbox". In other versions you can define a selection criteria (Advanced select).
When I writing the answer Kevin add also an image.
I don't think so, at least not without a macro. Depending on your situation, wouldn't using the replace components feature work? Then you wouldn't need to re-do all of your mates.
