SW2005, sp 5.0
I have a harness that we are soldering in a dc-dc converter between a connector and terminal lugs. This basicly creates two harness' in one harness assembly, because of the separation, but this is an inseparable assembly because of the soldering. The dc-dc converter does have connection points for the solder points like a connector.
How do I get the 2d harness board to reflect this correctly, if at all possible? It will only show one half of the wires and then I get the damn message about deleting lines when I try to move things around. Is this even possible?
I believe that this should be possible with 2006 SP04 but I can't say for certain. I'll try to get someone to check it out for you.
Development Manager - Routed systems.
