Can someone tell me how to create a sheetmetal flat pattern? (see corner plate.jpeg)
It has to be done in all four corners (see attachment: 1761-390_001), what is the easiest way?
The sheetmetal has too goo from the top too the bottom, and it may consist of several welded parts.
Thanks Dave
Good morning Dave,
I was just looking at your assembly again;
Do you need to have double thickness in the corners or could you design your chute with that corner a part of the chute. In some applications and materials I could see the need to have double thickness in the corners because of the wear factor.
It would save material and time if you could design the chute with that profile in the corner and just stitch weld a wear flat in the corner.
Later,
John
