It seems that to have a variable value associated with a file, there needs to be a control connected to that variable on the file card. This is fine, but I need to create and use variables that are purely for internal system use, and I don't want to clutter up the card (and confuse the users) by displaying a lot of cryptic information that is only used by the system itself.
The obvious solution would be to hide the control that links to the variable (XX.Visible = False in VB) but this is not possible in EPDM. I also tried to place the control way outside the normal viewing area of the card then re-size the card smaller so that the control can't be seen, but unfortunately EPDM won't allow you to make a card smaller than the area taken up by its controls
So if I want to use a variable - any variable - for a particular card, I must link it to a control and stick it on the card where everyone can see and be confused by it. Can anyone think of a way around this curious limitation?
Try leaving that blank Brian. Believe I originally tried using % and got the same results with the control still visible. So now currently my logic looks like the following:
