I know how to make a cone a sheet metal part.
Can a slanted cone like this be made into a sheet metal part
Good afternoon George,
Yes, use the lofted bend feature,
Later,
John
I get a message that the sketch should contain a single open profile, so I should put a gap somewhere in each sketch?
Delete the shell and the loft, then edit sketch 6 and sketch 1, put a small split in the circle and then select the loft sheet metal bend feature, give it the thickness that you want.
That worked, thanks!
Later,
John
