I am trying to create different configurations of the same part. I'm not removing anything just changing sizes. I created a new configuration and proceeded to start changine the dimensions and when i switched to back to the previous configuration it also changed. I've tried checking the "suppress features" in properties and still no luck.
When you double click on the dimension to edit it for the new config, in the dimension modify box, on the lower right, there is a pull down menu. Check the one that says "this configuration only" The dimensions in the other configs will be un affected.
