Does any else find that often when you save an assembly, when looking through a saved camera view, the view in the graphics window appears to jump backwards. The actual camera position doesn't change (if you render, the view is as it should be), but the graphics window appears completely wrong as if you have moved backwards by 20 steps!
Bizarrely, the same thing happens when I change configurations.
Opening another file, then going back again, seems to fix the issue... I just wonder if this happens to anyone else, and if there is a solution. Its been bugging me for quite a while, definitely since SW2010 (now using SW2011 SP4).
Tom
I'm on 2010 sp5 and have seen something similar. It occours for me when I have a large assembly open. I get the image flicking to the previous view and back again. I find it is not only confined to camera views but does become more annoying there.
I an using a quadro 1700 500 MB grapic card with the correct driver. I think I may need a larger graphics card.
