I need help. I have a macro that runs and archimedes spiral sketch points on a plane. However, I would like the sketch points to either be sketched on a surface, or for the sketch points to be brought to the surface. This is because I want to find the z-coordinates of the points on the surface.
Thank you for your help!
_________________________________________________________________________________________________________________________
Dim Part As Object
Dim boolstatus As Boolean
Dim Rad As Double, f As Double
Dim N As Double, Nt As Double
Dim dR As Double, R As Double
Dim i As Double, ang As Double
Private Const Pi As Double = 3.14159265358979
Set Part = swApp.ActiveDoc
'Create a projection plane
boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
Dim myRefPlane As Object
Set myRefPlane = Part.FeatureManager.InsertRefPlane(8, 0.005, 0, 0, 0, 0)
Part.ClearSelection2 True
Rad = 20 'Radius mm
f = 0.5 'Feedrate mm/rev
N = 72 'No. of points/rev
Nt = Rad / f * N + 1 'Total No. of points
dR = f / N 'Feed/point
Dim X As Double, Y As Double
' create a point on projected plane
boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", _
0, 0, 0, False, 0, Nothing, 0)
Part.SketchManager.InsertSketch True
Dim skPoint As Object
For i = 0 To Nt
R = Rad - dR * i
ang = (360 / N * i) 'Mod 360
X = R * Cos(ang * Pi / 180) / 1000
Y = R * Sin(ang * Pi / 180) / 1000
Set skPoint = Part.SketchManager.CreatePoint(X, Y, 0) '0.0012, 0.000077, 0)
Next i
