MSMark Sussmes05/02/2012
I have got a model of a canting keel yacht inside of a domain within Solidworks. It is a solid body cut out from inside of a domain box.
I am importing this into Design Modeller (DM) within Ansys V13.0 to run fluid flow analysis over the hull. Whenever i import the model into DM it either wont import the model or it imports it but doesn't seem to recognise the keel and bulb.
I can import just the yacht and then create the boundary box withing DM and remove the material that way but still it will not recognise the Keel/Bulb.
I have attached the Solidworks files for a yacht on its own and also with an exisitng domain built within Solidworks.
I am using Ansys V13.0 for this analysis. Could anyone point me in the correct direction as to what the issue may be. I am reasonably new to DM as a modelling tool so it may simply be the import options not being set correctly. Has anyone got any ideas?
Many Thanks
